Aironet 1231's that drop from the network
Mar 23rd, 2007
I have 5 1231 access points that will not work on my network. I have updated the config's on 7 other AP's that work fine.
We where updating the configuration to allow web based management and tacacs+.
I have copied the correct conifg's from a working ap into a non working ap and only changed the internal ip address and the ap will not work.
Exmaple:
no service pad
service password-encryption
hostname AMR_ORG_AP15
enable secret xxx
clock timezone GMT -5
ip subnet-zero
ip domain name xxx
aaa new-model
aaa group server radius rad_eap
server 10.10.1.104 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server tacacs+ tac_admin
server 10.10.1.104
cache expiry 1
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default group tac_admin
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default group tac_admin
aaa accounting network acct_methods start-stop group rad_acct
aaa cache profile admin_cache
all
aaa session-id common
dot11 ssid amriwpa
authentication open eap eap_methods
authentication key-management wpa
crypto pki trustpoint TP-self-signed-2161964427
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2161964427
revocation-check none
rsakeypair TP-self-signed-2161964427
username xxx password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid amriwpa
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.100.14.12 255.255.0.0
no ip route-cache
ip default-gateway 10.100.2.2
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
snmp-server community aromr5 RO
snmp-server host 10.10.1.2 arwmr5
snmp-server host 10.10.1.5 arwmr5
tacacs-server host 10.10.1.104 key xxx
tacacs-server directed-request
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.10.1.104 auth-port 1645 acct-port 1646 key xxx
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
bridge 1 route ip
line con 0
logging synchronous
login authentication local_auth
transport preferred all
transport output all
stopbits 1
line vty 0 4
authorization exec admin_methods
login authentication admin_methods
transport input all
line vty 5
transport input all
line vty 6 15
transport input all
sntp server 10.1.2.1
end
I have updated the IOS sofware to the latest addition, with no success.
Lawrence
john.preves Sat, 03/24/2007 - 23:46
  • Silver, 250 points or more
further define 'not work'..
What specifically does it not do?
lfranchini1 Sun, 03/25/2007 - 06:47
I can not telnet into the item. I can not access
it device through the web interface. I can ping the device and that is about it. No wireless enable devices even detect a radio signal.
rseiler Sun, 03/25/2007 - 11:03
Are you trying to telnet or https to these APs using the wireless network or via the Ethernet network (10.100.0.0/16)?
Be sure you are testing this from the console or using ssh via the Ethernet network, NOT WIRELESS!
If you upgraded these APs to 12.3(11)JA1 or 12.3(8)JEA1 then you may be experiencing the ssl bug that fails ssl negotiation. http would work if you enabled it. You can do a 'debug ip http ssl errors' and see the '%HTTPS: ssl negotiation failed' messages. Note that you will need a 'term mon' from an ssh or telnet session or 'logging console debugging' if using the console (NOT recommended for debugs).
Otherwise, you are just dealing with a config or implementation issue.
Note that you should remove the last 15 vty lines with the command 'no line vty 5 15'.
john.preves Sun, 03/25/2007 - 16:13
You cannot browse into the web interface because you have 'no ip http server' on.
You cannot telnet most likely because of all that crap you have under 'line vty x-x'.
Which I think the above post actually said more elequently but I didn't understand it the first time... sorry man I'm working on it.
lfranchini1 Mon, 03/26/2007 - 05:31
thank you all for your insight. I will make the changes you have pointed out. I just find it weird that the other 7 access points are working fine with the configuration.
lfranchini1 Mon, 03/26/2007 - 05:54
We use the AP's to access the network for authenticated users.
I am accessing the devices through the intra net
using: https:10.100.0.0/16 through Ethernet or by console cable or telnet into through Ethernet.
I have not been testing through wireless.
We are using Version 12.3(7)JA2.
I have tried to remove the last vty lines with the listed command in enable mode and could not it. stated the following: % Can't delete last 16 VTY lines
rseiler Mon, 03/26/2007 - 10:25
You need to be running 12.3(8)JEA1, minimum, to incorporate all bug fixes. It doesn't make any sense to troubleshoot an issue that may have been fixed since Nov, 2005 (the IOS you are running, which is also deferred as of Mar 23, 2006.
The command to remove the last 10 vty lines is:
'no line vty 5 15'
If that doesn't work then you are not running recent code...
lfranchini1 Mon, 03/26/2007 - 10:51
ok ,
I have flashed a access point to 12.3(8)JEA1.
I have enable access up to the point I change to my new tacacs+ server ip address in the "security - server manager" of the http webpage.
As soon as I apply the ip address it locks me out unless I am in throigh console at the time.
I get the following message:
The server 10.100.14.12 at level_15_or_view_access requires a username and password.
I use what I believe is the correct username/password for the access. It's the one listed in the config and shows up presently.
I can set the radius server to the new address fine. I have enable access to the device.
rseiler Mon, 03/26/2007 - 11:15
I'm not sure what you are doing or what you are trying to accomplish.
Looking at your above config, you haven't defined 'admin_methods' anywhere so you don't have access via telnet, ssh, or http.
Are you doing this through the GUI or command line?
If you have other APs that work, look at their config, I would bet they either have 'admin_methods' defined or have a different method defined under the vty lines.
lfranchini1 Mon, 03/26/2007 - 11:26
We are setting up management thru the secure http. We want to use network id's to change settings on the access point and update the tacacs+ ip address change.
I will update the IOS again.
I have tried to duplicate the settings on the devices from those that are working with no luck.
rseiler Mon, 03/26/2007 - 11:28
You don't have to upgrade the IOS again!?
Just check my above comments on the missing 'admin_methods' aaa method and compare it to other working APs...
lfranchini1 Mon, 03/26/2007 - 13:32
I took your advice and tried to add add the following command to line vty 0 4
it states the following:
AAA: Warning authorization list "admin_methods" is not defined for EXEC
I am not sure what this means. I see "login authentication admin_methods" on both configurations.
though I do not see admin_methods listed under my aaa settings.
