Redaundancy on Pix
Mar 23rd, 2007
Hi Experts,
We have 2 ISP's consider SP-A and SP-B. Both are connected to Router. We have default routes on Router to SP-A and SP-B. Router is connected to PIX. Patting has been performed for both the ISP's. Now I need some redundancy on PIX so that SP-A fails SP-B takes over or vice versa. I cant use two PIX. Please let me know the solution.
Cheers,
Nik
abinjola Fri, 03/23/2007 - 17:08
Lan---->Pix------>ROuter---ISPA
ISP B
The default route on FW would be pointing to Router....why do you need redundancy on FW if your Router is doing load balancing (both ISP terminating of Router)
Whether your ISP A fails or ISP B fails FW woudl still be pointing the traffic to router.. so your ROuter has to do the ISP falback mechanism
