AS 2509 Loading as.cfg ... [timed out]
Answered Question
Mar 23rd, 2007
Have set up an AS at my home lab, and trying to figure out if this behavior is normal or not. The problem is that when i am doing config this line keep coming up all the time, and is disturbing my inputs.
my boot conf is as follow:
8192K bytes of processor board System flash (Read ONLY)
IP unicast fastswitching has to be enabled on the physical interface
Loading cisconet.cfg ... [timed out]
Loading as-confg ... [timed out]
Press RETURN to get started!
Running conf is as:
AS#sh ru
Building configuration...
Current configuration:
version 11.1
service config
service slave-log
service udp-small-servers
service tcp-small-servers
hostname AS
no ip routing
no ip domain-lookup
interface Loopback0
ip address 100.1.1.1 255.255.255.255
no ip directed-broadcast
no ip mroute-cache
no ip route-cache
interface Ethernet0
no ip address
no ip mroute-cache
no ip route-cache
shutdown
no mop enabled
interface Serial0
no ip address
no ip mroute-cache
no ip route-cache
shutdown
no fair-queue
interface Serial1
no ip address
no ip mroute-cache
no ip route-cache
shutdown
ip host SW2 2002 100.1.1.1
ip host SW1 2001 100.1.1.1
ip host R2 2004 100.1.1.1
ip host R3 2003 100.1.1.1
ip host FSW 2005 100.1.1.1
ip host R1 2008 100.1.1.1
no ip classless
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line 1 8
transport input all
line aux 0
line vty 0 4
password xxxxxxxx
login
end
AS#
In advance thanks for any help.
Correct Answer by ankbhasi about 9 years 10 months ago
Hi Friend,
Can you issue a command " no service config" and do "wr mem" then reload the router and I believe this will resolve your issue.
Ankur
*Pls rate helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Sat, 03/24/2007 - 02:50
Hi Friend,
Ankur
Alf Martinsen Sun, 03/25/2007 - 01:48
A small step for you, but a great step for me :-), pursuing my CCNA (ICND) so i do not have so much experience yet.
Thanks that solves my "annoying" problem.
Rated it.
