Policy routing
Answered Question
Mar 24th, 2007
I am having a hard time with policy routing.
There is a 1841 router having 2 WAN connections (aDSL), each with different ISP.
What I am trying to do originate traffic from each fastethernet to different dialer an vice versa.
Let's say di0<->fa0/0 & di1<->fa0/1.
Imagine two different LANs, each using its own WAN connection.
Till now I have:
interface FastEthernet0/1
ip address x.y.z.a 255.255.255.248
ip policy route-map ROUTEMAPNAME
access-list 101 permit ip x.y.z.0 0.0.0.7 any
route-map ROUTEMAPNAME permit 1
match ip address 101
set interface dialer1
Thanks in advance
Correct Answer by Richard Burts about 10 years 4 months ago
Stavros
It seems to me that your Policy Based Routing should work with either set interface or set next-hop.
If you want to direct all traffic coming into fa0/0 to go to dialer 0, all traffic coming into fa0/1 to go to dialer 1, all traffic coming into dialer 0 to go to fa0/0 and all traffic coming into dialer 1 to go to fa0/1 then you will need ip policy configured on all 4 interfaces.
While the parts of config that you posted look ok, you have not indicated whether that part is working or not. Perhaps you can clarify.
I would also like to ask a clarifying question: is it possible that a packet could arrive at dialer1 with a destination address on fa0/0? If that did happen what would you do? Your statement of requirements seems to indicate that you would forward it to fa0/1 anyway. Is this an accurate statement of requirements?
There was a discussion in NetPro a while back about something similar to this situation and suggestion made that perhaps VRF lite might be a way to get the results that you want - almost like 2 separate routers in the same box. Perhaps you can think about this alternative.
Rick
Overall Rating: 5 (1 ratings)
royalblues Sat, 03/24/2007 - 02:28
  • Green, 3000 points or more
Friend,
Let me know if i understand your requirement here.
You want the traffic from Fa0/1 to exit via Dialer1 and fa 0/0 via dialer0
You should better use the next hop ips in this case.
Configure 2 LAN pools corresponding to the LAN pool.
USe route-maps and instead of set interface use set ip next-hop of the dialer interfaces.
Narayan
akaliptos Sat, 03/24/2007 - 10:15
I need all traffic originating behind fa0/1 to be routed via dialer1, as well as all inbound traffic to dialer1 to be forwarded to fa0/1.
As if there are 2 routers (di0-fa0/0 & di1-fa0/1).
Correct Answer
Richard Burts Sat, 03/24/2007 - 10:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Stavros
Rick
akaliptos Sat, 03/24/2007 - 12:12
Of course!!! On all interfaces, as well as remove the default route (this is what I was missing!)
Thank you, your post "unstuck" me!
Stavros
Richard Burts Sat, 03/24/2007 - 12:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Stavros
I am glad that my post was able to help you to find the solution to your issue. And thanks for the rating. The forum is a very helpful place to discuss problems and to find solutions. I encourage you to continue your participation in the forum.
Rick
