Hi Manoj,
Yes all line cards are plug and play and if your IOS release running on your supervisor supports these cards, they will automatically get detected and will move to OK state.
After that it is only the port configuration which you have to do on the line cards interfaces.
Ankur
*Pls rate all helpfull post
