linecode issue with CCM 5.1(1) and MGCP gateway (2801 router)
rasmusan1
Hello
i have the following setup:
Cisco Callmanager 5.1(1)
Cisco 2801 router 12.4(9) with VWIC2-1MFT-T1E1-E1 module
in then CCM i have setup the gateway as an MGCP gateway.
The issue is, that every time i reboot the router, and the CCM tries to register with the gateway, it sets the linecode to ami (which is the standard for T1), and then the CCM cannot register with the gateway. THen i have to manually enter the "linecode hdb3" command in the router CLI to get the CCM to register. and then everything works just fine, until i reboot the router, and then the linecode i set back to ami.
i tried different IOS versions, without any luck.
can anyone help me out with this problem ? thanks in advance...
here is the config output:
hostname ccmgate
boot-start-marker
boot-end-marker
card type e1 0 2
enable secret "REMOVED"
enable password "REMOVED"
no aaa new-model
resource policy
network-clock-participate wic 2
ip cef
no ip dhcp use vrf connected
ip dhcp pool IPTX
network 10.10.10.0 255.255.255.0
default-router 10.10.10.2
option 150 ip 10.10.10.3
ip domain name "REMOVED"
ip host CCM 10.10.10.3
isdn switch-type primary-net5
voice-card 0
controller E1 0/2/0
pri-group timeslots 1-16 service mgcp
interface FastEthernet0/0
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip http server
no ip http secure-server
control-plane
disable-eadi
voice-port 0/2/0:15
cptone DK
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.10.3
ccm-manager config
mgcp
mgcp call-agent CCM 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
line con 0
password "REMOVED"
login
line aux 0
line vty 0 4
password "REMOVED"
login
scheduler allocate 20000 1000
end
Kevin Rice
Level 4
Level 4
Rasmus,
It appears you are configuring the controller as a PRI. The linecode "ami" is traditionally used for analog lines, PRI is digital or not channelized. Do you have a analog T1 or digital PRI?
it's a E1 PRI (digital)
You can remove the 'ccm-manager config' command so the config is not downloaded from the CCM which may be causing your problem....
You can also do a 'debug ccm-manager config-download' I believe (or similar) to see what commands the ccm-manager config is pushing down.
