easy vpn with gre plz help urgent
Mar 24th, 2007
hi guys plz answer my 2 queries
1) i wanted to develop easy vpn over gre but i failed comming to a conclusion that gre cannot be used with easy vpn, am i right ??? if wrong kindly tell me how to develop it..
2)if i m right than wats the alternative ? during my search i found dvti stating that it provides the same stability as that og gre over ipsec site to site, does it mean that it actually works like a gre tunnel ??? like if i run a tracert from a pc at one end will it give me a result of 1 hop like in gre ??? plz tell me its urgent
thanks in advance plz reply
shaila_rox Fri, 03/30/2007 - 00:03
hi martin thanks for the reply but its not helpful, none of the links addresses my issue :(, well thanks alot to ALLAH that i was able to meet my objective of developing easyvpn over tunnel interface and successful routing was also done, there is still a minor problem but i m looking forward to it, i was a bit disappointed regarding replies coz no 1 did, i think perhaps no 1 has ever encounter this problem so if any 1 want to do the same u can ask me i will be glad to help u guys out,
thanks again martin
