FWSM Code upgrade procedure
Mar 24th, 2007
I have (2) 6509's with FWSM's in slot 9. I need to upgrade the code tonight since the FTP process does not function since there is a bug in the current code. Whe is the procedure to upgrade the code from 2.3.4 to 2.3.4.8 , what is the potential outage time? Also the FWSM's are in an active standby state not active/acative.
Thank you,
Gerry
varakantam Sun, 03/25/2007 - 01:53
You could use TFTP Client on the FWSM for upgrade
copy tftp: flas:image (use it from system space if running in multiple mode)
You can upgrade without outage give minor version difference
a) Make sure the state sync is on
b) Upgrade the Standby
c) Reboot the standby using failover reload standby
d) After standby comes up and does state sync upgrade active and make standby active using "failover active"
e) reload previous active (current standby) using failover reload-standby
vettiyattil.par... Mon, 03/26/2007 - 22:19
Step 1 Make the new software image available on a TFTP server, or make the MSFC a TFTP server by using this command:
msfc(config)# tftp-server bootflash:image name
Step 2 If the MSFC is the TFTP server, make sure you have a VLAN interface on the MSFC reachable from the module. For example:
a. On the MSFC, enter these commands:
router(config)# interface Vlan30
router(config)# description to_fwsm_vlan_30
router(config)# ip address 10.20.30.2 255.255.255.0
router(config)# no ip redirects
b. On the module, enter these commands:
nameif vlan30 inside security100
ip address inside 10.20.30.5 255.255.255.0
c. From the module make sure that you can ping the MSFC, by entering this command:
FWSM# ping 10.20.30.2
10.20.30.2 response received -- 0ms
Step 3 From the module enter the copy tftp flash command:
FWSM# copy tftp flash
Address or name of remote host [127.0.0.1]? 10.20.30.2
Source file name [cdisk]? c6svc-fwm-k9.1-1-0-207.bin
copying tftp://10.20.30.2/c6svc-fwm-k9.1-1-0-207.bin to flash:image
[yes|no|again]?yes
The output shows the MSFC as the TFTP server.
Step 4 Reload the module by entering this command:
FWSM# reload
Proceed with reload? [confirm]
The link is
http://www.cisco.com/en/US/customer/products/hw/switches/ps708/module_installation_and_configuration_guides_chapter09186a0080159caa.html#wp1049356
P
