IPsec VPN with 2 PIX firewalls and 1 2600 router
Mar 24th, 2007
Does anyone know if it's possible to setup a full mesh VPN topology when using 2 Cisco PIX firewalls and 1 Cisco 2600 router. I have no issues at all getting the VPN up between the PIX firewalls and 1 tunnel up between the router and PIX. The problem i am having is when trying to get the second tunnel from the router to the second PIX up and running.
Jon Marshall Sun, 03/25/2007 - 01:35
All the devices you mention can do multiple tunnels so there should not be an issue with creating a full mesh between them.
Suspect it may be a configuration issue ? Perhaps you could post the configs.
bhansen70 Sun, 03/25/2007 - 08:47
Here is the Configs i have right now. The PIX VPN is working just fine so i think there is something missing on the Router side of the VPN to the 2 PIX firewalls.
Jon Marshall Mon, 03/26/2007 - 01:43
Which VPN tunnel is not working ?
In your router config it is a bit confusing as access-list 101 refers to which matches all your other configs on the pix firewalls.
Access-list 102 however references 192.168.3.x. Unless this is a typo this would mean that this traffic would get natted and hence would not initiate a VPN tunnel ie.
Pix1 thinks traffic should be coming from However because your access-list 102 is referencing 192.168.3.x/24 then the 192.168.31.x traffic from your 2600 will get natted and hence will not match at the pix end.
Does this make sense ??
bhansen70 Mon, 03/26/2007 - 20:41
Yes that did make some sense. I was able to get the tunnels all up and working in the mesh configuration by just rebuilding ACL 101 to deny the other 2 remote offices to bypass NAT.
access-list 101 deny ip
access-list 101 permit ip any
Then i just used my nonat policy to match ip address 101
Once i did that everything came up just fine and working great now.
Thanks for your input it was good information.
