easy vpn plz help
Mar 25th, 2007
hi i m trying to make easy vpn with dvti and i have done till exhanging routes thru eigrp !! but i m not able to ping the advertised routes, when i ran the debug ip packets command i got the following like routed via FIB, any1 has any experience in dvti plz plz plz tell me its very urgent, my overall objective is to run routing over easy vpn using gre tunnel, but i cannot use gre with easy vpn so i used dvti but i m facing this...
plz advice
thanks in advance
ivillegas Fri, 03/30/2007 - 06:54
  • Silver, 250 points or more
Check if you have configured ip address on the insde interface of the VPN client.
I think your problem is related to cisco bug CSCek19217 or its duplicate CSCek18575.
