access list
Mar 25th, 2007
hi expert,
what is the purpose by adding stablisted in the access list ?
access-list 101 permit tcp any eq telnet host 192.168.1.1
access-list 101 permit tcp any eq telnet host 192.168.1.1 establisthed
Danilo Dy Sun, 03/25/2007 - 08:42
  • Blue, 1500 points or more
This is to permit any packets returning to a host from already establish connections. When the datagram has acknowledged (ACK) or reset (RST) bits set (indicating an established TCP session)
acbenny Sun, 03/25/2007 - 08:45
sorry, can you explain more ? i still not understand
Jon Marshall Sun, 03/25/2007 - 08:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The established keyword allows tcp traffic to pass if there is an ACK or RST flag in the packet. If there isn't then the packet will not match that line and will be checked against the rest of the access-list if there are any more entries.
Put simply by using the established keyword you are making sure that the connection has already been initiated and that you are allowing traffic that is part of an already established connection.
What your access-list line says is only allow traffic with a source port of 23 to go through to the host 192.168.1.1 if the host host 192.168.1.1 has already initiated the connection.
Jon
