Router Forwarding between VLANs
Answered Question
Mar 25th, 2007
I'm trying to communicate 2VLAN's in a 2900XL to a 2600Router. My 2600 supports dot1q so I changed the encapsulation and set 2 sub-interfaces on Eth0/0. However, seems there no comm. between 2hosts on the diff. subnets (e/vlan)I've configured both VLANs and set the trunk on Fa0/16 which is part of both VLANs 1 and 3. Any clues on this?
Thank you.
Correct Answer by mahmoodmkl about 10 years 2 months ago
Configure the Link between the two swithces as Trunk link.i.e
switchport mode trunk
and see tht u dnot enable portfast on the ports used for trunking.
Mahmood
Overall Rating: 4.3 (3 ratings)
glen.grant Sun, 03/25/2007 - 08:31
  • Purple, 4500 points or more
Probably have to post both configs . Also what model is the 2924 ? A old 4 meg or newer 8 meg model . The older ones didn't support trunking i don't believe .
rodrigo2673 Sun, 03/25/2007 - 09:13
Hi thanks for the fast response!
the 2924 is 8meg model.
ankbhasi Sun, 03/25/2007 - 09:27
  • Cisco Employee,
Hi Rodrigo,
Instead of using multi vlan command on siwtch interface can you try this command
interface FastEthernet0/16
Ankur
rodrigo2673 Sun, 03/25/2007 - 10:04
Thanks Ankur! it works now. There is comm. now from host to router.
ankbhasi Sun, 03/25/2007 - 10:21
  • Cisco Employee,
Hi Rodrigo,
Nice to know that it worked for you.
Ankur
*Pls rate all helpfull post
rodrigo2673 Sun, 04/08/2007 - 10:43
Im following the same configuration but now I added another sw2926-XL. The problem is: I cannot get to comm. I've connected a crossover between the 2 sw. (Fa0/17) STP is working in FWD mode in both interfaces. However, when I ping the router says Request Time Out. I've also put Fa0/16 which is the host on VLAN 02.
Please, can you help?
Rod
Correct Answer
mahmoodmkl Sun, 04/08/2007 - 22:18
  • Gold, 750 points or more
Mahmood
ankbhasi Sun, 04/08/2007 - 23:42
  • Cisco Employee,
Hi Rod,
Can you please confirm if you are trying to ping ro touter from the switch? If yes have you det a default gateway on your switch pointing to router ip address?
Ankur
rodrigo2673 Sat, 06/30/2007 - 05:09
I am trying to comm.3 routers on a hub-and-spoke topology. The HUB router comms.with the "left" router on a point-to-point connection fine. However, the int.S1(multipoint)connected to router "right" does not comm. Please, find attached 3conf.files of each router.
I hope you can see what is missing in my config.
Thanks.
Rod
rodrigo2673 Sat, 10/06/2007 - 13:25
I hope you can help me since I'm having problems configuring my PIX 501. I have set e0 and e1 static ip addresses and they both comm. with their own segments. HOwever, I can't comm. from e1 through e0.
I've set in both NAT (inside) 0 0 0 and outside as well. There are no packet going out from any of both nics.
regadrs,
Rod
