03-25-2007 01:02 PM - edited 03-03-2019 04:17 PM
Hi, can someone recommend for me a low cost 24-port fast-ethernet cisco switch that has L2 and L3 functionality for creating VLANs and routing internally between VLANs and routing externally.
Thanks in advance.
Solved! Go to Solution.
03-25-2007 01:19 PM
Absolutely. Note, some features are only in "IP services" or better image. But L3 and basic routing are in all images.
Hope this helps, please rate all useful posts!
03-25-2007 01:07 PM
Hi Friend,
Because you asked for a single switch which can work as L2 and L3 both, the starting siwtch model will be 3560
Have a look at this link
http://www.cisco.com/en/US/products/hw/switches/ps5528/index.html
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7d.html
But incase you just want a basic l2 feature the lowest model will be CE500 switch
http://www.cisco.com/en/US/products/ps6545/index.html
Ankur
*Pls rate all helpfull post
03-25-2007 01:10 PM
Thank you.
03-25-2007 01:19 PM
03-26-2007 02:35 PM
It would be a good idea to compare IPBASE and IPSERVICES to make sure you won't need something down the road. For example, multicast routing is not supported in IPBASE.
