vpn works but cannot access local LAN...
Mar 25th, 2007
I have cisco vpn client connecting to a 1721 at the office. the client connects and i can access the office LAN but but not the local LAN. i do have the box checked in vpn client to allow local LAN access. please help!
thanks!
Matt
here's the config:
Current configuration : 3901 bytes
version 12.2
service password-encryption
hostname Cerberus
boot system flash c1700-k9o3sy7-mz.122-11.T10.bin
aaa new-model
aaa group server radius RADIUS-SERVERS
server 192.168.69.1 auth-port 1645 acct-port 1646
aaa authentication login LOGIN group RADIUS-SERVERS local
aaa authorization network NETGROUPAUTH local
aaa session-id common
username mattheff password 7 07572C4D5A011C034F
username mikeheff password 7 030952000307244A48
clock timezone CST -6
clock summer-time CDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip subnet-zero
ip domain name heffnet.net
ip name-server 68.94.156.1
ip name-server 68.94.157.1
ip dhcp excluded-address 192.168.69.1 192.168.69.99
ip dhcp excluded-address 192.168.69.111 192.168.69.254
ip dhcp pool HEFFNET_LAN_POOL_1
network 192.168.69.0 255.255.255.0
default-router 192.168.69.254
dns-server 68.94.156.1 68.94.157.1
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group VPNGROUP
key 8mathef8
dns 68.94.156.1 68.94.157.1
domain heffnet.net
pool VPN_CLIENT_POOL
acl 102
crypto ipsec transform-set VPNSET1 esp-3des esp-sha-hmac
crypto dynamic-map DYNMAP 10
set transform-set VPNSET1
crypto map VPNCLIENTMAP client authentication list LOGIN
crypto map VPNCLIENTMAP isakmp authorization list NETGROUPAUTH
crypto map VPNCLIENTMAP client configuration address respond
crypto map VPNCLIENTMAP 10 ipsec-isakmp dynamic DYNMAP
interface Loopback0
ip address 1.1.1.1 255.255.255.252
interface ATM0
description Heffnet WAN/SBC DSL Interface
no ip address
no atm ilmi-keepalive
pvc 0/35
pppoe-client dial-pool-number 69
dsl operating-mode auto
no fair-queue
interface FastEthernet0
description Heffnet LAN Interface
ip address 192.168.69.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip policy route-map VPN_ROUTE_MAP
speed auto
interface Dialer69
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 69
ppp chap hostname cerberus
ppp chap password 7 040306071B29494851
ppp pap sent-username [email protected] password 7 07572C4D5A011C034F
ip local pool VPN_CLIENT_POOL 192.168.70.200 192.168.70.253
ip nat inside source list INTERNAL interface Dialer69 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer69
no ip http server
ip access-list extended INTERNAL
deny ip 192.168.69.0 0.0.0.255 192.168.70.0 0.0.0.255
permit ip 192.168.69.0 0.0.0.255 any
logging 192.168.69.1
access-list 101 permit ip 192.168.69.0 0.0.0.255 192.168.70.0 0.0.0.255
access-list 102 permit ip 192.168.69.0 0.0.0.255 any
route-map VPN_ROUTE_MAP permit 10
match ip address 101
set ip next-hop 1.1.1.2
alias exec s show ip interface brief
alias exec sr show running-config
line con 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
logging synchronous
line vty 0 4
privilege level 15
logging synchronous
line vty 5 15
privilege level 15
logging synchronous
scheduler allocate 4000 1000
end
Kamal Malhotra Mon, 03/26/2007 - 07:08
  • Cisco Employee,
Hi Matt,
The config looks good. Please make sure that you get a route for 192.168.69.0 255.255.255.0 network only after connecting with the VPN client. Please also match the 'route print' output of the client before and after connecting. One more thing, I hope that the local network is not 192.168.69.0.
HTH,
Please rate if it helps,
Kamal
