disable SNMP trap on subinterfaces
Mar 25th, 2007
Hi all,
I want to disable receiving SNMP trap status from subinterfaces but still will receive trap from physical interface st. Already entered the command "no snmp trap link-status" but still DFM keep receiving traps. See my configuration below. Any suggestion?
interface GigabitEthernet0/0.1204
description *****for testing*****
encapsulation dot1Q 1204
ip unnumbered Loopback1001
ip helper-address ******
interface GigabitEthernet0/0.1800
encapsulation dot1Q 1800
muttman15 Sun, 03/25/2007 - 18:48
I would try adding this line
"no logging event link-status "
This was an issue that was hammering our syslog server and adding both your line above and this line seemed to do the trick
Joe Clarke Sun, 03/25/2007 - 21:13
What version of IOS is this device running? Are you certain it is traps you are receiving, and not syslog messages? Please provide an example trap.
ariesc_33 Sun, 03/25/2007 - 21:59
it is the interface status alarms...
ios version
(C7301-SPSERVICESK9-M), Version 12.4(6)T2
Event_Description OperationallyDown
Component IF-10.*.*.*/1902 [Gi0/2.3535]
Type L2VLAN
OperStatus DOWN
InterfaceCode CODEUNKNOWN
DuplexMode FULLDUPLEX
AdminStatus UP
LastChangedAt 16-Mar-2007 12:26:22
IsFlapping false
MaxSpeed 1000000000
Mode NORMAL
Martin Ermel Mon, 03/26/2007 - 00:55
No DFM does not handle syslog messages, the only thing is that DFM can be configured to generate syslog messages for a specific event and forward it to a syslog receiver ( e.g RME);
Aries,
look at line 1,4,7 and 8 of the event:
'Event_Description OperationallyDown '
'OperStatus DOWN '
'AdminStatus UP '
'LastChangedAt 16-Mar-2007 12:26:22'
this indicates, that it is not an event caused by a received trap, but generated based on the responses from the device to an active poll from DFM;
Enabled by default, DFM polls the gig interface if its 'ifAdminStatus' is set to 'UP';
but as its 'ifOperStatus' indicates 'DOWN', DFM assumes this is a fault;
DFM interface rules are based on the assumtion that all interfaces which are administratively up should also forward traffic (operational up);
You have 2 Options:
in DFM set the managed state of this interface to false;
on the device,configure the 'shutdown' command on the interface;
ariesc_33 Mon, 03/26/2007 - 01:13
Would it be possible to poll only the physical interface [gig 0/1] and not the subinterface [gig 0/1.222]?
Martin Ermel Mon, 03/26/2007 - 06:14
open the detailed device view for the device:
DFM > Device Management > View Device Details
select the device, go to Interface Status - Interfaces
there you should see all interfaces and you can change the managed state for each
after all changes, apply the changes by selecting
Configuration > Polling and Threshold > Apply Changes
ariesc_33 Mon, 03/26/2007 - 23:28
it takes about 30 minutes to open interface status probably because routers has around 4000 subinterface.
Only solution i can see right now is to disable polling from lms to router and enable on the router the manual trap sending..?
Any other suggestion?
Martin Ermel Fri, 03/30/2007 - 09:01
what happens if you 'shutdown' the subinterace on the router?
with this command the SNMP ifAdminStatus is set to down and it shouldn't be an issue for DFM anymore.
I don?t know of a cli command to disable a bunch of (sub-)interfaces in DFM to workaround the GUI
Other possibility could be to generate an action (e.g. email) based on syslog for the physical if..
