rebecca.richards Sun, 03/25/2007 - 22:55
You're close with access-list # 2 above, but it needs to be:
access-list 101 permit tcp any host 192.168.1.2 eq 22
- bec
acbenny Sun, 03/25/2007 - 23:14
ic, how about the #1 access-list ?
it is just any host can make session with destination port which is tcp port 22 to host 192.168.1.2 ----is it also right ?
rebecca.richards Sun, 03/25/2007 - 23:33
With SSH, the client binds to a "random" TCP high port, which you cannot predict. So your ACL #1 above would not match at all, as you're specifying that the clients are bound to 22/tcp
It is the _server_ that is bound to 22/tcp, which is what you match on, thus #2.
acbenny Sun, 03/25/2007 - 23:44
then does this pattern is correct ?
Access-list 101 permit tcp/udp [source ip address][source ip address 's destination port][destination ip address][destination ip 's destination port]
