Cisco AAA Privilege Level Configuration ??
Mar 25th, 2007
Hi All
I am trying to configure AAA Privilege Level Configuration on a local based Router (not using tacacus or radius)using AAA , following command line
aaa new-model
aaa authentication login default local
aaa authorization exec default local
username john privilege 9 password 0 doe
username mark privilege 6 password 0 six
username poweruser privilege 15 password poweruser
privilege exec level 6 show running
privilege exec level 8 configure terminal
as per the above configuration john will have the rights to excute sh run and conf t more and mark will have only rights to sh run and will not be able to excute conf t ....but even after setting the
privilege mark is able to excute conf t
Any help and suggestion will be greatly appreciated
sundar.palaniappan Mon, 03/26/2007 - 12:25
Your config works fine in my lab router. Here it is...
R1#show run | i aaa|user|pri
aaa new-model
aaa session-id common
username poweruser privilege 15 password 0 poweruser
privilege exec level 6 show running-config
R1#172.30.1.11
Trying 172.30.1.11 ... Open
User Access Verification
Username: john
Password:
R1#config t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#exit
R1#ex
*Mar 4 14:59:20: %SYS-5-CONFIG_I: Configured from console by john on vty0 (172.
30.1.11)it
[Connection to 172.30.1.11 closed by foreign host]
R1#172.30.1.11
Username: mark
Password:
R1#config t
% Invalid input detected at '^' marker.
R1#show run
Building configuration...
If you are still having problems remove aaa completely and put the config back in and check.
Sundar
