Speed settings related to WAN routing using Cisco 1801
Mar 25th, 2007
I have set up WAN on my 1801 router. The speeds are significatly slower than when I use a broadband router previously supplied by the ISP. I need to be able to set the MTU to 1352. Must I set up GRE to do this and if so, on how/on which interface? I am new at this.
Jon Marshall Mon, 03/26/2007 - 00:28
You do not need to setup GRE to change the mtu on the interface. Under the interface configuration mode:
"ip mtu 1352"
That should do it
