03-26-2007 03:57 AM
Hi,i have problem with DCA serveur. When i attempt to open DCR i have that notification: Error in communicating with DCA Server.
DCA Server may be down. Please start the DCA Server and then refresh the page.
How can i start the DCA server ? i've tried to restart the server Ciscoworks with command line: net stop crmdmgtd and net start crmdmgtd. But problems persist.
help me please
03-26-2007 05:49 AM
check the DCRServer status with
pdshow DCRServer
what is the status? if it is down, try to restart it with
pdexec DCRServer
was the hostname of the server changed?
try to recreate the server certificate:
Server > Security > Single-Server Management > Certificate Setup
and restart the all daemons (net stop..)
is there any hint in dcr.log?
if this does not help, you should enable debug for dcr
03-28-2007 09:31 AM
when i use the command pdshow DCRserver it indicate that process is never started et when i try to restart it i have that notification:
Error: get reply from server failed
03-28-2007 09:36 AM
If the process is Never started, then one of its dependencies failed to properly initialize. DCRServer depends on TomcatMonitor, CmfDbMonitor, and EssMonitor. What are the states of those processes?
03-29-2007 10:30 AM
CmfDbMonitor and EssMonitor are in running normally state but TomcatMonitor's state is : administrator has shut down this server. when I try to start it, it remains on this same state .help please!
03-29-2007 10:33 AM
Check your service startup parameters for the CiscoWorks services in the Service Control Panel. Please provide the complete list and their parameter.
03-29-2007 10:49 AM
Services are:
ANIDbEngine:service started
CRMDmgtd:service started
RMEDbEngine:service started
Tomcat:service started
RmeOrb:service started
Apache:service started
CmfDbEngine:service started
crmrsh:service started
crmlog:service started
crmtftp:service started
EPMDbEngine:service started
FHDbEgine:service started
INVDbEngine:service started
03-29-2007 10:52 AM
No, I want the startup parameter (i.e. Manual, Automatic).
04-02-2007 08:11 AM
the startup parameter is automatic for all service except FHDbEngine and INVDbEngine their startup parameter is manual
04-02-2007 08:24 AM
This is your problem. All services EXCEPT CiscoWorks Daemon Management, the CWCS services, and the IPM services MUST be set to Manual startup.
Here is a list of which services MUST be manual:
After changing these parameters, reboot your server.
04-02-2007 09:46 AM
I've changed these parameters but problems persist.
I think that the problem is due to the fact that I left the domain where it was at the time of the installation of LMS. Indeed I cannot reach any more the server by its name which is serverlms but by its address IP only.
http://serverlms:1741 don't work
http://192.168.10.10:1741 work for example but with error to DCA server
04-02-2007 09:49 AM
If the hostname of the server has changed since you installed LMS, you will need to follow the 10-step procedure at http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_d/cs303/usrguide/diagnos.htm#wp1078582 to update the hostname within LMS.
04-02-2007 10:24 AM
Thanks you very very very much, my problem is solved.
03-29-2007 10:34 AM
ProcessRC is 1 for TomcatMonitor process
