IPCC Express APPADMIN
Mar 26th, 2007
After installation IPCC worked fine but now when i open http://ip CM/appadmin the page cannot be displayed. Can i fix it or do i have to reinstalle IPCC. Can i reinstall IPCC over the existing installation without loss of settings?
david.macias Mon, 03/26/2007 - 06:31
  • Blue, 1500 points or more
I think I remember seeing an article on cisco.com about different things you can do to troubleshoot this error, however I can't find it right now. However, you can reinstall without losing anything.
david
Gergely Szabo Mon, 03/26/2007 - 07:21
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
Double check
- CRS Engine Windows service running?
- IIS server running?
- browser's cache and history have been erased?
sebastiaanp Mon, 03/26/2007 - 07:26
-CRS running
- IIS running
- Browser cache / hist erased
neil.woolloff Mon, 07/16/2007 - 02:14
Sebastiaanp,
Did the PDF offered by david.macias work for you or did you do a re-install as I am having the same issue as yourself.
rgrds,
neilw
sebastiaanp Mon, 07/16/2007 - 07:15
I have reinstalled IPCC after the reinstallation it didn't work. I placed a fixed ip of the server in the IIS administration tool.
neil.woolloff Tue, 07/17/2007 - 00:18
Will try that and see what happens and post up the results.
Neilw
[edit]
tried as suggested an still nothing.
Am following install guide to recover and hope that works.
[/edit]
