03-26-2007 05:31 AM - edited 03-03-2019 04:18 PM
I have configured one of the cisco 2600 router ethernet port with two IP address. I connected this port to two WAN links and the connection works as long as the Pimary IP network is up. If the WAn link for the primary IP network fails, the secondary IP network cannot communicate with the other WAN link.
Can someone please help me solve the problem
Solved! Go to Solution.
03-29-2007 05:40 AM
Tigist,
That's correct the only config required was
on the router and the switch.
Glad it is working now.
OW
03-26-2007 06:37 AM
HI,
Do you mean by Single Router Port to 2-WAN Links - how ?
Can you please post the Configuration. It depends upon the Routing Protocol you use.
Regards, Guru Prasad R
03-26-2007 08:19 AM
Tigist
I agree with Guruprasad that we need more information about your environment so that we can understand it and be able to give better answers to your question.
From your description I would guess that the problem may be that whatever is connected on the second WAN link does not have a route to the subnet of your secondary address. It may also be a possible problem with the configuration of the default gateway on the devices in the subnet of the secondary address.
So if you can provide more information about the situation we may be able to find better answers.
Rick
03-26-2007 09:44 PM
Rick, Guruprasad,
I have a 2600 router with two ethernet ports. One of the ports is configured with the branches network IP. The second ethernet port is configured with two IP addresses, primary and secondary.
I have subscribed two WAN links from an ISP (one of the link is redundant) to connect to the Head Office Network. My intention is to enable the branch to use both WAN links with load sharing and be able to work if one of the WAN links fail.
The WAN link is broadband network and the devices of the ISP at the branch is cisco UBR and Cisco SOHO ADSL.
The problem I am having is that when one of the WAN links fail (the primary IP addressed link), the secondary IP address configured at the Router cannot communicate with the WAN link.
below is the configuration of the cisco 2600 router
Building configuration...
Current configuration : 911 bytes
version 12.3
hostname XXXXXX
boot-start-marker
boot-end-marker
enable secret
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0/0
ip address 172.31.12.221 255.255.255.0
ip helper-address 192.168.0.2
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.31.22.2 255.255.255.0 secondary
ip address 172.31.2.2 255.255.255.0
duplex auto
speed auto
router rip
version 2
network 172.31.0.0
ip classless
ip http server
line con 0
line aux 0
end
Tigist
03-26-2007 11:52 PM
HI Tigist,
2 - Ways of Load Balancing using RIP:
a. Per Destination Based
b. Per Packet Based
If 2 WAN Links to Head Office is of Equal Cost Links means it is easy to Load Balance.
a.Per-destination load balancing means the router distributes the packets based on the destination address. Given two paths to the same network, all packets for destination1 on that network go over the first path, all packets for destination2 on that network go over the second path, and so on.
b.Per-packet load-balancing means that the router sends one packet for destination1 over the first path, the second packet for (the same) destination1 over the second path, and so on.
load balancing is on a per-destination basis:
Router# config t
Router(config)# interface Ethernet 0/1
Router(config-if)# ip route-cache
load balancing is on a per-packet basis:
Router# config t
Router(config-if)# no ip route-cache
Rate the Answers if this Helps ! !
Thanks & Regards, Guru Prasad R
03-27-2007 12:04 AM
Guru Prasad R,
My problem is not load balancing but that the secondary IP address doesnot communicate with the redundant WAN link When the Primary WAN link fails.
Primary IP address 172.31.2.2 and the UBR link IP address 172.31.2.1
Secondary Ip address 172.31.22.2 and ADSL link IP 172.31.22.1
When the UBR link fails, the Secondary IP address does not communicate with ADSL link. meaning when I ping 172.31.22.1 from my router no response when the Primary WAN link fails.
do you have any Idea how I can solve this
Thank you
Tigist
03-27-2007 01:13 AM
try the no auto-summary option
ciao flash
03-27-2007 01:23 AM
flash
I have already configured no auto-summary option
tigist
03-27-2007 02:22 AM
Have you tried to work with individual links ?
connect individual link1 and link2 to individual desktops and make sure that you are able to browse in both.
I suspect your ISP has routed your secondary IP also on your Primary WAN IP.
S. Shantharam
03-27-2007 02:58 AM
S.Shantharam
Link1 and Link2 work fine when I configure the cisco ethernet port as primary IP.
The links also work fine with the secondary address if the primary line is ok.
The problem is the secondary IP address is not functional if the Primary IP network WAN link fails.
Tigist
03-27-2007 04:34 AM
Hi Tigist,
I am attaching two images
1. your present Network
2. My view to check the links
You are doubting about secondary IP dependent on Primary address. The same I conveyed in a different way. Because we also assign IP blocks to customers depending on their requirement, and I have come across many similar situation.
S. Shantharam
03-27-2007 05:26 AM
Shantharam.suryanarayana,
the attachement tigist.jpg is my senario. while searching the forum, I came accross thi post that I think answers my question that the secondary IP address is indeed dependant on the Primary.
Posted by: medan - Senior Consultant, NCS Pte. Ltd. - Mar 9, 2007, 11:48pm PST
Topic: function of Secondary
"Note: If any router on a network segment uses a secondary address, all other routers on that same segment must also use a secondary address from the same network or subnet. "
Thank You
Tigist
03-27-2007 03:00 AM
HI,
Here i don't agree with shantharam.
Because, when we look into the Configuration posted:
Primary & Secondary IP Address are from 2 Different Subnet Ranges. So, there will not be a chance of routing the Secondary IP Adress via Primary WAN IP.
But, Did you check the Individual Links seperately before doing this Configuration (or) Can you check with ISP for the routing details of Traffic on their Routers.
03-27-2007 03:09 AM
guruprasadr,
I have checked the individual links and both links work fine. I am wondering if the secondary IP address is dependant on the primary address.
Tigist
03-27-2007 07:29 AM
Tigist
I do not understand the topology or I do not understand what you are trying to do. Your posts talk about 2 WAN links. Are both WAN links connected to the same address that has primary and secondary IP addresses? Perhaps you can explain the connectivity of how both WAN links are connected to the router?
In looking further at your config I may have an idea of the problem. I notice that you are running RIP version 2 and that it includes both of the interfaces. The RIP updates sent out the WAN interface will have the source address set as the primary IP address. Even when the primary link is down the router will be sending RIP updates with source address of the primary address. I suspect that the remote device does not accept the routing updates because it considers them to be from an invalid next hop address. It might be helpful to post the output of show ip protocol and of show ip route from both routers when the primary link is down. I suspect that it will show that the remote router does not have routes from this router (and I am not 100% sure that this router will have routes from the remote router).
Rick
