how to remove Fabric Segmentation under Fabric Manager
Mar 26th, 2007
hi
my fabric is build with 4 MDS
there are now totally isolated (no connection between switches) but under
Fabric Manager all switches are seen as
fabric isolated in VSAN1
i desinstalled/resinstalled Fabric Manager
rebooted switches , still isolated
how to remove this from Fabric Manager
and to see really 4 independants MDS ?
thanks in advance
JYP
tblancha Mon, 03/26/2007 - 10:48
There is an uninstall.bat file that you should run. Then after that, delete the directory and flush it from the recycle bin. Then reinstall and do not check the accelerate discovery checkbox.
jjpeyrache Tue, 03/27/2007 - 02:06
i did that , but configurations remains after uninstall and delete directories
since tied to hidden directory called
.cisco_mds9000 under C:\
what is the purpose of this hidden directory ?
thanks
JYP
tblancha Tue, 03/27/2007 - 03:34
That is the directory to delete. The 1.x and early 2.x versions used that as the directory to put the program and cache.
jjpeyrache Tue, 03/27/2007 - 03:45
so, shall i let alive directories
c:\programs files\cisco systems\mds 9000 ?
JYP
Trending Topics: Storage Networking
