Call disconnections
Mar 26th, 2007
I have a CCM cluster installed in ma company. Unfortunately, I heard that sometimes there are some "call disconnections" after a few seconds, or 30 sec, it's never the same. This problem happends sometimes with internal and external calls.
I think It is not a Signaling error; just in case :When a call is established, are there still SCCP packets which are transmisted to the CCM ?
All my Cisco swiches are configured with Auto Qos, is it the best way to make Qos ?
I don't know from where the problem come, do you have an idea?
Best regards,
nonosensei Tue, 03/27/2007 - 02:32
Region codec is G.711 ( Network is well dimensionned, and there is no so much distance between people). Auto Qos is configured on all the equipments (3560).
Sometimes calls from/to the PSTN are dropped, sometimes internal ( just IP) are dropped..
How can I configure the Qos in a better way than Auto Qos ?
Best regards
alessandro.dona Tue, 03/27/2007 - 03:31
During a call there aren't sccp packets from or to CCM(unless you perform a call waiting or something else).
your internal calls go through WAN or do they go just trough LAN.If so i don't think it colud be a problem of QoS!
About external calls try to keep a log of the router and to discover the disconnect code.
