Amit Singh Mon, 03/26/2007 - 08:52
  • Cisco Employee,
What OS you are running on both the sup engines?
If you are running Hybrid OS on Sup 2 and has IOS on Sup 720, then you can use Cisco' CAT OS to IOS config tool and change the config to the desired IOS one. All the commands might not work but most of the commands will work for you.
http://www.cisco.com/cgi-bin/Support/CatCfgConversion/catcfg_xlat.pl
Also, Make sure that you put Sup720 in Slot 5 or 6 in a 6506 chassis, otherwise it will not power up.
Let me know if you have any questions.
HTH,please rate if it does.
-amit singh
mathiasivn Mon, 03/26/2007 - 09:01
On sup 2 The ios Version is "disk0:c6sup22-dsv-mz.121-23.E2.bin"
Do i need to bring down the box or its hot swapable ???
Im not sure what ios there on sup 720
Amit Singh Mon, 03/26/2007 - 09:14
  • Cisco Employee,
You are running IOS on Sup 2 so the config will not be an issue if you have ordered Sup720 with IOS on it. Just back the Sup2 config on a TFTP server and put the config on Sup720.just check if all the commands and other features that you are runnin on Sup2 should be supported on the Sup720 OS.
If you dont have Native IOS on sup 720 then do the following:
1.Either convert the hybrid OS on Sup720 to IOS and use the above listed step for configuration.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
2. Or you have to manaully config Sup720 for CatOS commands.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_1/confg_gd/index.htm
Both Sup720 and Sup2 are hot swappable but they cannot co-exist in the same chassis.So you have to put one sup in and take another sup out. please plan a schdeuled downtime for the same. Also check the release note for Sup720 to make sure that all the hardware modules that were running on Sup2 are supported with Sup 720.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_4498.htm
HTH,Please rate if it does.
-amit singh
mathiasivn Mon, 03/26/2007 - 09:30
I've only these two modules
8 8 port 1000mb GBIC Enhanced QoS
48 48 port 10/100/1000mb EtherModule
Hope there should not be any problem
My worry is OS on sup 720 ??? since ive not ordered .. what is the best bet 2 check ?
Ive spare 4506 with me ? does this chase support sup 720 ??
Amit Singh Mon, 03/26/2007 - 09:43
  • Cisco Employee,
Cat 4506 chassis doesnot support Sup 720.
If you havenot ordered Sup720 as of now then you shouldnt be worry about it.All the 6500 line cards are supported with Sup720. You must make sure that you order the Sup720 with the latest IOS that support your both the line cards. You should order the IOS which atleast meet the minimum IOS requirement. Please see the link below and check the minumum and recommended IOS requirement for your linecards. just make sure that order Sp720 with the required one.
-amit singh
mathiasivn Tue, 03/27/2007 - 03:05
I've sup 720 with me .. But Im not the one who order . My worry is what OS it has ?? Cat OS or native .. becouse i ve no clue about cat os
Catalyst 6500 supervisor 720 fabric msfc3 pfc3b.
mahmoodmkl Tue, 03/27/2007 - 03:54
  • Gold, 750 points or more
It will have native IOS.
Mahmood
