Delete a single cert on CSS 11501
Answered Question
Mar 26th, 2007
Hi there...I am trying to delete a single SSL cert on the CSS. I cannot figure out how to delete just one. When I do a "sh ssl files" I see many certs there, and just want to delete one.
the only command I can find is "ssl clearfiles" which you execute from debug mode. And it deletes them all.
Please advise,
thanks is advance!
Correct Answer by hassan_oudeh about 10 years 3 months ago
dear yycsandman007
its good that the problem solved..
but can you please tell me how ? because i want to know and i want to delete my files also :P
one more question if you have an idea ??
i want to change the name of the files (the .cer files or the rsakey.pem file )
is it possible ? or i need to regenrate them ?
i have this problem because when im trying synchronize the config from the active CSS to Standby, the associate command will be deleted as the certificates files name is different
please help if you hava an idea ?
Overall Rating: 3 (2 ratings)
Correct Answer
hassan_oudeh Tue, 03/27/2007 - 12:22
dear yycsandman007
yycsandman007 Tue, 03/27/2007 - 14:28
clear ssl file "text string used to encode the file"
Hope this helps!
As far as changing the file name goes, don't know how....sorry.
