Symmetrical High-Bit Rate DSL Interface Card for Cisco Routers
Mar 26th, 2007
Hey and thanks ind advance.
Need to know if this interfacecard is kompatible with my 2611 cisco router, it says.
The modular routers that support the new card are the Cisco 2600XM
Does that include 2611 ???
And if so, any clue where to buy a used or cheap new one would be appreciated.
Thanks for you help
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Mon, 03/26/2007 - 11:17
Do you mean WIC-1G.SHDSL ?
It may be a problem on the 2611 non-XM because you may lack enough flash and ram to host the new image needed.
Best source for used hardware is is always the leader auction site.
Hope this helps, please reate all useful posts!
