3745 to 3845 Upgrade. How to tell what version of DSU-T1 card is installed
mtpearson
Does anyone know how to tell what Version of WIC1-DSU-T1 card is installed? We have a 3745 and are looking to move to a 3845 but we need to know if our cards are compatible.
deepenmalla
Do " show diag " from the exec or previleged exec mode. It will show all the details about the WIC card installed in your router.
Thanks deepenmalla. I was able to get the part number but I do not know if it is compatible with the 3845 or another possible upgrade platform, the 7206vxr.
Does anyone know of a place on the site that has that compatibility matrix?
Only WIC-1DSU-T1-V2 is supported in 3800, not in 7200VXR. There is integrated CSU/DSU in 7200VXR dependent on PA configuration.
Here is the table of platform a WIC-1DSU-T1 card supported (which does not include 3800 and 7200VXR) http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800b1501.shtml
Here are the relevant module and interfaces for 3800 http://www.cisco.com/en/US/products/ps5855/products_relevant_interfaces_and_modules.html
Here are the relevant module and interface for 7200VXR http://www.cisco.com/en/US/products/hw/routers/ps341/products_relevant_interfaces_and_modules.html
Here is the Cisco Router Guide http://www.cisco.com/application/pdf/en/us/guest/products/ps5855/c1031/cdccont_0900aecd8019dc1f.pdf
Medan,
Thanks for the CRG link you've posted.
- Matt
