Direct URL to UT End Host report
Mar 26th, 2007
We are wanting to create a URL that will directly access the UT report associated with that endhost. The idea is to have a direct link from our network docs that would open up the report in CW that would give us the port and device that the server was attached too.
I have researched using the cmexport utility and specifing a query - but it seems you ahve to already have the query defined.
I would like to just pass a URL with IP address of the server/device.
Joe Clarke Mon, 03/26/2007 - 10:07
We have a tool called the User Tracking Utility that installs as a task bar item in Windows that gives this kind of quick access to end host details (see for download).
Beyond that, the closest URL you could get that would allow you to specify arbitrary end host search criteria is http://server/cmapps/ . Unfortunately, this is not exactly what you want as you would still need to type in the data yourself.
