ospf load balancing
Answered Question
Mar 26th, 2007
hi
we are facing load balancing problem.
Details of network set up is given in attached msword document.
Any suggestions..
Thanks in advance
Subodh
Correct Answer by parthibanp about 10 years 2 months ago
Try enabling per packet load balancing on the involved interfaces (seria&ethernet) on all the rotuers involved.
Overall Rating: 5 (1 ratings)
Amit Singh Mon, 03/26/2007 - 10:20
  • Cisco Employee,
Subodh,
Can you please post the config from both R1 and R3 and also "show ip route "
-amit singh
bapatsubodh Tue, 03/27/2007 - 11:19
Dear Mr. Singh,
all routers R1, R2, R3, and R 4 are all 7507 series routers having more that 800 rouets. SO i think it's practically difficult to caputre o/p or sh ip route. Can i post any particular routes , wherein router shows two paths of equal cost to destinations.
Pls. ack back.
( Also I will try per packet switching if possible as mentioned in second reply )
Thanks and Regards.
Subodh
Correct Answer
parthibanp Mon, 03/26/2007 - 11:11
