fa 0/1 to be used as back up interface
Mar 26th, 2007
I need to configure my 2nd ethernet inteface to be an backup interface for the primary one as a backuplink which should come up when the first link has some physical issues. Can i use backup interface command for this , what will be the ip needed to configure for the backup interface (ip unnumbered primary interface)
Thanks for any suggestions
Overall Rating: 4 (1 ratings)
ahmadabuzayyad Mon, 03/26/2007 - 14:18
if you talking about switch it will be done by using etherchannel either layer 2 or 3
but if you work with router you can bridge the two interfaces.
rate if it is help you.
parthibanp Mon, 03/26/2007 - 21:43
Iam talking about a router. I want to have one ethernet as a stand by for the other and start forwarding traffi when the first one fails.
Will bridging help in this case.
Thanks for your response
ahmadabuzayyad Mon, 03/26/2007 - 21:57
look in router you can't asign two interfaces with the same network if they work as layer 3 so by bridging them you just asign the configuration to the ogical interface created and the two phyiscal interfaces work as switch
