CSA Program VS Hotfix installation
Mar 26th, 2007
Hey Guys,
I have installed the latest hotfix for CSA and it looks and feels the same way as the normal program. Is this enough as an intallation or should I install the package itself. if yes, what should I do in this case?
Overall Rating: 4 (2 ratings)
oabduo983 Mon, 03/26/2007 - 19:58
Hi JP,
When I installed the latest hotfix, I meant to say the MC hotfix. I think it was revision 91. There was nothing at all other than the OS installed on that server, and the hotfix looks like it installed the program with the latest version. I wanted to make sure that what I have done is right and I do not have to install the actual package...
The hotfix is just as big as the actual program (about 150 MB file to download)...
Thanks in advance...
Once you applied the CSAMC hotfix, from the CSAMC look under Systems > Agents Kits.
You should see kits for &
CLick on the kit link and click on "Download URL" to download.
Now you need to deploy the agents to your servers.
Also, you can check under Systems > Hosts. Under Host Status check the Software Version.
It should say "Agent is running the latest software".
