Unable to convert 7940 SCCP Phone to SIP
Mar 26th, 2007
I have a Cisco 7940 IP Phone that was connected to a Cisco CallManager 5.1. The firmware version is 8.0.4.
I would like to convert it to a SIP Firmware.
So I tried to followed procedure given here :
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp7960/addprot/mgcp/frmwrup.htm#wp1046556
But It doesn't work. The phone always try to download the file SEPmacadresse.cnf.xml and nothing more. Would someone have a more precise description on how to migrate from SCCP to SIP ?
What is the exact files that I have to put on my tftp server ? What to they have to include ? What is the syntax ?
Here is the file I have in my tftp root :
OS79XX.TXT
P0S3-08-2-00.loads
P0S3-08-2-00.sb2
P003-08-2-00.bin
P003-08-2-00.sbn
SIP000d659XXXXX.cnf
SIPDefault.cnf
SEP000d659XXXXX.cnf.xml
In SEP000d659XXXXX.cnf.xml, I put this :
-> loadInformation8 model="IP Phone 7940">P003-08-2-00</loadInformation8>
Thanx for your help
Bastien.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 03/26/2007 - 13:19
  • Hall of Fame,
    Founding Member
There is a mispelling in the file names, should be P003.. or P0S3... ?
Anyway, you can try a factory reset.
copy the .loads file as term40.default.loads
Power off. Press # while powering on. Release when led are flashing. press 123456789*0#.
Phone should request above file and all the firmware components.
Hope this helps, please rate all useful posts!
BABARCHE Mon, 03/26/2007 - 23:04
Thanx Very Much
It works perfectly.
Bastien.
m-ketchum Tue, 04/03/2007 - 11:45
Hi, what was the problem exactly..the filename or did you need to reset to default?
Mike
paolo bevilacqua Tue, 04/03/2007 - 11:48
  • Hall of Fame,
    Founding Member
The original poster is unlikely to read again this thread since his problem has been solved.
Now, what's your problem? :)
m-ketchum Tue, 04/03/2007 - 11:52
Oh, I just wanted to know exactly what was wrong with his setup because I only want to go through it one time. I haven't attempted it yet.
I'm assuming all I need to do is load up the correct files in a tftp server, manually configure the phone to point to the tftp server, and then reset the phone and watch it download the new firmware??
Mike
m-ketchum Tue, 04/03/2007 - 12:07
Mike
paolo bevilacqua Tue, 04/03/2007 - 12:14
  • Hall of Fame,
    Founding Member
Yes. You do not even need to manually configure the phone. Even DHCP in a production CM environment will upgrade the phone as long the files are present.
m-ketchum Tue, 04/03/2007 - 12:20
Cool....so if I have a stand alone phone say at my house, as long as there is IP connectivity to the tftp server on my laptop there should be no problem. Thanks!
