VLAN Config
Mar 26th, 2007
HI Experts,
Just a quick question.
What is the recommened way to configure a VLAN on a catalyst?
sw#vlan database
sw(vlan)# Vlan 10
or
sw(config)#vlan 10
Config mode or Vlan database mode???
My new 642-812 book says the former, but i always configure the latter.
Some clarification would be great.
Stephen
christian.stock Mon, 03/26/2007 - 13:43
When I go into my new 3750's and type vlan config I get:
Switch#vlan database
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
So....it looks like they want config mode.
stephen.stack Tue, 03/27/2007 - 01:38
Hey,
Thats exactly what i got also. In the new BCMSN ciriculum, the SWICTH(config)#vlan 10
command seems to be the way forward.
If anyone can shed any light on this i would be grateful.
i.e.
Is this now the offical way to configure a vlan?
What Catalyst IOS did this take effect?
When is the VLAN database command being phased out?
Stephen
haroon.shaikh Thu, 03/29/2007 - 15:27
Hi Stephen,
You can configure vlans from vlan database but cisco recommends the newer way of configuring vlans from config mode.
I think that some newer switches and routers wont allow you to use vlan database. So, its a best idea to start configuring vlans from config mode. Hope that helps.
Cheers,
Haroon
* Please rate if helpful
