AP DHCP Option 43
Mar 26th, 2007
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html#wp125304
Hi ,
i'm using the procedure that is signed in the previous link , but not work.
I use AP 1000 series model 1010.
I've read that the AP 1000 series is trated with a Aironet 1200.
Sameone have tested this type of procedure whit WLC , windows 2003 server whit dhcp (option 43) and AP 1010.
Thanks for your help
FC
csannedhi Mon, 03/26/2007 - 15:52
That document explains how to migrate an autonomous AP to a lightweitht AP (read the title). If you have 1000 series APs then they are already running lightweight firmware on them, you don't need to deal with this document. 1200 and 1000 series APs look completely different http://tinyurl.com/htekb
g.rienstra Thu, 03/29/2007 - 12:07
I Suppose u are using the VCI "Airespace 1200"
instead of "Cisco AP c1130" ? If so beware of the capitols? If the APs are in a different vlan asthe controller is it might help to add a helper address onthe interface vlan of the APs to the controller (management address)
G
