Limit bandwidth on a switch-port?
Mar 26th, 2007
We want to share an Internet-connection with a C2960 and limit the bandwith on each port (each customer on a port).
I try the parameter "max-reserved-bandwidth" on an interface but there was no difference in bandwith on this port.
Is there a way to limit the bandwith on a switch-port?
Or are there other opportunities?
Thanks!
ahmadabuzayyad Mon, 03/26/2007 - 14:12
You can limit the connection by police or shape the traffic based on customer requirments or you can use rate limt command.
For max-reserved-bandwidth is just how much you will remain for routing and other issue which is by default 75%.
I hope this is inforamtive for you and rate if it is.
B.R
Ahmadabuzayyad
serge_van_waes Tue, 03/27/2007 - 08:17
Thanks for the information.
I will explain a bit more....
We haven an Internetconnection of 10 Mb, connected on a C2960 switch. We want to limit the bandwidth on each switch-port to 1 Mbps.
What is the best command we can use on the switch? Do you have some examples for me? (I am not a Cisco specialist)
Thanks!
m.matteson Tue, 03/27/2007 - 08:43
if the 2960 is capable of Layer 3 switching (meaning routing) you could use a CAR policy. Commited Access Rate.
The Committed Access Rate (CAR) and Distributed CAR (DCAR) services limit the input or output transmission rate on an interface or subinterface based on a flexible set of criteria.
you can use the rate-limit command on the interface.
