VPN Connection IPsec: no ping response from remote site
Answered Question
hy guys
i have the fowling problem:
i can establish an ipsec connection (network to network) with the remote site. and i can access to the resources of the remote network. but not vice versa. from the remote network i can not access to any of my servers & co.. when i start a ping to one of my network devices (from remote network to my network) i do not receive a answer. i have spend a lot of time to troubleshoot this problem but i do not found the solution! is it a nat problem? pleas help me...
thank you for your help (and sorry for my english :-))
my config is attached: (PIX 506 v6.3)
Correct Answer by Jon Marshall about 9 years 7 months ago
Could you send the config for both ends please.
Overall Rating: 5 (1 ratings)
I have resolved the problem. The gateway in the configuration of the hosts was not the right one.
I have just replaced the entry with the correct one an it works! The hosts have correctly answered to my request but they return the answer over the false gateway. Result I do not receive any answer to my ping...
I know it?s a basic error?
ksherwood Wed, 04/25/2007 - 16:13
I actually want to start a new post but couldn't find where to do it so here goes....
I have a 6500 switch/router with a sup720 and IPSEC SPA from which I have configured a VPN to a remote site using the access method. Now I want to connect to another remote site in a hub and spoke type design, but I can't work out how to do this using a single WAN side port and IP address ???
ksherwood Sun, 04/29/2007 - 02:13
I have worked it out !!!
You create another crypto map of the same name but with another ID ie crypto map WAN 20
and then add the new peer.
I hope this will help anyone else because it's not clear in the doco :>)
