Guest WiFi asking for a key
Mar 26th, 2007
One our AP's which run secure SSID's and a guest SSID, we've received numerious complaints from users saying that the Guest SSID is asking for a wep key to be entered. I know there was a bug in regards to this, but is there no other solution then having the user upgrade their drivers yet?
s-doyle Mon, 04/02/2007 - 06:01
Configure VLANs in the switch and access point to disable WEP.
raun.williams Mon, 04/02/2007 - 06:44
My switch ports are trunked. We run multiple SSID's, the majority have WEP.. the guest does not. I can not disable WEP on our internal network SSID's. The problem as stated above, is with the Guest reporting it has a WEP key when it does not. I believe I have found the solution, by configuring the option of Multiple BSSID's under SSID Manager, however when doing this and setting our guest SSID to guest mode, my wlse reports my internal not broadcasting SSID's as broadcasting and some of them as rogue.
