Reroute a call back out to the PTSN - CME
Mar 26th, 2007
I am trying to translate an incoming fax call and reroute it back out to the PSTN to another Fax number is this possible ?
I am translating the incoming number into another number, and have a dialpeer matching that number pointing back out the PSTN, but with no success so far, just getting busy tone when calling in.
Would appreciate links to references/examples.
Thanks in advance
paolo bevilacqua Mon, 03/26/2007 - 15:03
  • Hall of Fame,
    Founding Member
How the call is coming in ? do you have did ? if did is working with ephones you can configure CFA on one of these, no need to translate.
anup.anand Mon, 03/26/2007 - 19:40
  • Silver, 250 points or more
This should work. Are you able to call the translated number from the CME phones? Please paste your configs.
Anup
