E1 access problem in SRST
Mar 26th, 2007
I upgraded the IOS and the IP Phone are registered, but for outgoing calls not works. I made a call using CSIM command and the call works. The router are connect to PSTN by E1 PRI.Pls. see the SRST config:
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address <IP CCM> port 2000
max-ephones 96
max-dn 120
access-code pri 9 direct-inward-dial
time-zone 11
date-format dd-mm-yy
This is the dial-peer for outgoing calls:
dial-peer voice 100 pots
destination-pattern 9
direct-inward-dial
port 0/0/0:15
Cristian
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Tue, 03/27/2007 - 14:59
9.T and variations are indeed right in most cases. To find out why calls are failing, do "debug isdn q931" and "term mon".
cristian.munoz Tue, 03/27/2007 - 15:05
Dear Paolo
See the debug q931.
Mar 23 04:08:45.011: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0091
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '6912'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81
*Mar 23 04:08:45.039: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8091
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 23 04:08:46.171: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0091
Cause i = 0x8090 - Normal call clearing
*Mar 23 04:08:46.191: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8091
*Mar 23 04:08:46.191: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0091
Paolo Bevilacqua Tue, 03/27/2007 - 15:11
Hi, there is no called number in setup. Sorry, I'm not familiar with CCM/SRTS, hope someone can help better.
cristian.munoz Tue, 03/27/2007 - 15:39
Hi,I either i see it.
I configured SRST using FXO and it has work fine, but this is my first tiem using E1 PRI.
I access to E1 channel but i can?t dial the follow digits.
Paolo Bevilacqua Thu, 04/05/2007 - 07:26
please change the dial-peer for outgoing calls to:
destination-pattern 9T
check again with "debug isdn q931" what number goes out, if 9 is not removed, you will need to configure a translation-rule to remove it (not difficult).
Hope this helps, please rate all useful posts!
pacameron Sun, 04/08/2007 - 03:55
Instead of using the 'access-code pri 9 direct-inward-dial' command, remove it and add 'secondary-dialtone 9'.
The 'access-code' commands actually creates temporary dial peers in the 20XXX range and these could be conflicting with your existing dial peers. You can check this by entering 'show call-manager-fallback dial-peer' while in SRST to see if this is happening.
With the 'secondary-dialtone 9' command, the router will play a different dial tone after dialing the '9' access code, this number and the rest of the digit string will then match on dial peer 100 (assuming the destination pattern on this dial peer is 9T) ... the leading 9 will be stripped off and the call should proceed correctly.
cristian.munoz Sun, 04/08/2007 - 07:06
Dear Paul
Last Thursday i run the command destiantion-pattern 9T and adding secondary-dialtone 9 , and this works!.
