result from show logging
Mar 26th, 2007
here is one of the entry :
*Oct 22 17:30:13.537: %SEC-6-IPACCESSLOGP: list 115 permitted tcp 213.123.134.23(0) -> 51.233.23.33(0), 62 packets
I would like to know if the " (0) " is representing the tcp port number ?
Thanks for help.
Jon Marshall Mon, 03/26/2007 - 23:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes, the number in the brackets after the IP address is meant to represent the port number. Do you know what the relevant IP addresses are.
A packet with a source port of 0 and a destination port of 0 looks like a crafted packet.
Jon
pakmanhon Tue, 03/27/2007 - 00:10
thanks for answering, however would you pls give me some more detail for the "crafted packet" ?
Any related website for reference ? thanks again.
Jon Marshall Tue, 03/27/2007 - 00:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Here is an article on crafted packets and firewalls.
http://www.securityfocus.com/infocus/1787
In essence packet crafting is all about manipulating data within the packet headers to try and probe/evade/penetrate security devices.
There are a number of freely available tools on the Internet that make crafting packets very easy.
Jon
pakmanhon Tue, 03/27/2007 - 01:04
Could you tell me why you think a source port of 0 and a destination port of 0 looks like a crafted packet?
many thanks.
Jon Marshall Tue, 03/27/2007 - 01:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Two things wrong with it
1) There is no service listening on port 0 so the destination port is suspect. Standard services would be for example
tcp port 20/21 = ftp
tcp port 23 = telnet
tcp port 80 = http
but nothing listens on port 0.
2) The source port should never be 0. Generally speaking the source port is dynamically generated on the client and is > 1024.
eg
client = 192.168.1.5
web server = 172.16.1.5
When the client connects to the web server
source IP 192.168.1.5 source port 12010
destination IP 172.16.1.5 destination port 80.
Note port 12010 was chosen at random, as long as it is higher than 1024.
Jon
Richard Burts Tue, 03/27/2007 - 19:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I do not believe that this is a crafted packet and that there is a simple explanation for the log message that you describe. Pretty obviously the access list used the log paremeter to report this traffic and the log parameter attempts to report the TCP or UDP port number involved. But if the access list has not examined port numbers then it can not report the port numbers and will report (0). If you can clarify the syntax of the access list used, I am confident that we will find that it does permit and deny by IP address but does not specify any checking of TCP or UDP port numbers.
Rick
pakmanhon Wed, 03/28/2007 - 03:07
here is my access list, just very simple:
interface Serial0
no ip address
ip access-group 115 in
ip access-group 115 out
no ip directed-broadcast
encapsulation frame-relay
interface Serial0.1 point-to-point
description connect to primary computer room
ip address 2xx.xxx.xxx.xxx 255.255.255.252
frame-relay interface-dlci 205
interface Serial0.2 point-to-point
description connect to secondsry computer room
access-list 115 permit ip any any log
Jon Marshall Wed, 03/28/2007 - 03:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
I have just setup this in a lab and Rick is spot on in this case and it is something i wasn't aware of either. As he says it is because your access-list references ip and not tcp or udp.
Apologies for misleading you in this instance although a lot of what i wrote is still relevant in terms of crafted packets etc. but in this case it is most definitely not a crafted packet.
Thanks for the information Rick.
Jon
Richard Burts Wed, 03/28/2007 - 07:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
You are quite welcome. I find that this behavior of access lists is frequently not well understood. And much of what you wrote about crafted packets is quite correct, but not the issue in this instance.
Rick
frkainvid Wed, 05/30/2007 - 04:39
I didnt realize this behaviour either. But what if i want to log the portnumber. If i for instance write a access-list:
permit tcp any any gt 0 log
permit udp any any gt 0 log
It will log tcp and udp allright. But it will potentially use alot of cpu and other protocols will use up lots of rows in the acl.
Any ideas?
Richard Burts Wed, 05/30/2007 - 05:16
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Fredrik
You are correct that the access list that you wrote will log the port numbers for all TCP and all UDP traffic going through the interface(s) where the access list is assigned. And it will consume some CPU cycles to do it, and depending on how you have configured logging (to console? to logging buffer? to syslog servers?) it will consume more CPU cycles to send the log messages to their syslog destinations. How much CPU cycles will depend on how much traffic is going through the interface(s). So you must make a choice: does the port level information have enough value to be worth the overhead that it requires to get it?
I am not sure that other protocols will use lots of rows in the ACL. There is not much else that I know where you need to specify port numbers. So most people when they are doing an access list like this will add one more line of permit ip any any. This allows all IP traffic other than TCP and UDP to go through (probably without logging - unless there is some reason that you want to log ALL traffic through an interface).
Rick
