1721 to ISa ipsec tunnel
Mar 27th, 2007
where can i find a template config to configure a 1721 to ISa ipsec tunnel and what ver of IOS is required for the 1721?
spremkumar Tue, 03/27/2007 - 01:31
Hi Brad
Is it going to be router to router IPSEC Tunnel ? or what kinda device going to be there in the remote end ?
for configuration purpose you can refer the below link ..
Also refer Cisco IOS Software Feature Sets under the link to find out the feature set required in your box to have ipsec configured..
bradlesliect Tue, 03/27/2007 - 02:55
Its going to be a router to ISA connection.
1721 <-> MS ISA server ( needs to create an IPSEC tunnel.
