e1 connection
Mar 27th, 2007
Hi all, on an e1 connection, whats is the max speed in the uk you can have, and does e1 have a constant speed, ot does it have a burst rate ?
spremkumar Tue, 03/27/2007 - 04:06
Hi Carl
You can have a max speed of 2048 Kbps which is 2 Mbps.
You will have a constant 2 Mbps speed on both in and out ways.
The speed control on the router port lies with the SP to which you have the connectivity..
