Danilo Dy Tue, 03/27/2007 - 06:11
For you to access your switch from inside? I don't see a problem with that.
vitripat Tue, 03/27/2007 - 19:01
Im not sure about the requirements of doing so. Also, if you configure the default-gateway to the failover IP of the Outside interface of PIX, this wont be a good idea because if PIX recieves the traffic on the Failover IP, PIX will not route that traffic. This IP is only used for failover communications between the Outside interfaces of PIX.
Vibhor.
