03-27-2007 04:10 AM - edited 03-05-2019 03:07 PM
Is RSPAN supported on the following switch?
C3550 Software (C3550-I9K2L2Q3-M), Version 12.1(22)EA5
I'm having problems trying to configure a remote-span vlan on the switch above.
03-27-2007 04:43 AM
Hi Friend,
Yes RSPAN is supported on the above release. Can you explain what problem you are facing?
Ankur
03-27-2007 05:41 AM
my mistake I was trying to configure the remote span vlan via
(vlan)#
rather than
(config-vlan)#
