LMS2.6 User Tracking
Answered Question
Mar 27th, 2007
Is there a way to automate report generation on user tracking by sending it as email automaticaly?
Correct Answer by Joe Clarke about 10 years 2 months ago
You can schedule UT reports to run and archive the results. You can then have an email sent saying that the report was run, but the email will not contain the actual report data. Instead, it will include a URL on where to review the report.
There are also CLI utilities (ut and cmexport) that will allow you to run UT reports from the command line. By wrapping those in custom scripts and cron or at, you can have report data automatically emailed to you.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 03/27/2007 - 10:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
