Integration between Cisco RADIUS and RSA
Mar 27th, 2007
Ciao. I need some help to configure the RADIUS, activating the RSA "NEXT TOKEN CODE" feature. Can you help me?
Danilo Dy Tue, 03/27/2007 - 07:03
If you have maintenance with RSA or your product is license, you can contact their support and they can give a step-by-step guide in PDF.
I've done similar using RSA and RADIUS for network staff login to all Cisco network devices using a token. The step-by-step guide provided by their support is very helpful.
Danilo Dy Tue, 03/27/2007 - 07:35
I can't find it since it was 2 years ago, beside the RADIUS I was using is the one that comes with RSA. The guys in RSA are great!
