Configuring CE510 thru the HTML GUI
Mar 27th, 2007
I have a Ce510 Content Engine at a Customer Site that needs to be configured. The customer purchased the product a couple of years ago, but did not really do anything with it until recently.
I need to find a manual or documentation that specifically addresses using the HTML GUI ( the box is running ACNS Version 5.1), as there are many configuration options within the GUI, but I have as yet not been able to find anything on the Cisco Web Site for configuring it.
Please Help.
joquesada Thu, 03/29/2007 - 20:14
Unfortunately, what you are looking for is not available. This due that the options of the GUI are somewhat limited for initial configuration, but complex setups and commands are only availabe from the CLI.
This link shows the configuration options of the 5.1 ACNS code:
Please notice appendix A; which explains the menu options of the GUI.
Please consider upgrading the ACNS code of your customer?s CE, due that there are many enhancements and bug fixes on the lastest code 5.5.x.
Thanks & Regards,
Jose Quesada.
