AAA Authentication Failure
Mar 27th, 2007
I have the following configuration on a 2950 Catalyst switch
aaa new-model
aaa group server radius radServ
server 10.1.9.100 auth-port 1645 acct-port 1813
server 10.1.8.100 auth-port 1645 acct-port 1813
aaa authentication login default group radServ local
I unfortunately cannot authenticate via the AAA server. What is possibly the problem.
I can ping from the switch to the AAA server.
Vivek Santuka Tue, 03/27/2007 - 08:21
  • Cisco Employee,
Have you added the following :-
radius-server host 10.1.9.100 key
radius-server host 10.1.8.100 key
Vivek
marksenteza Tue, 03/27/2007 - 08:31
Yes I have. I've crossed checked that the keys match, and they do.
magurwara Tue, 03/27/2007 - 12:05
What protocol are you using for the 2950? i.e. RADIUS (Cisco IOS/PIX 6.0) or TACACS+
What do you see in the failed attempts log on ACS?
Also, have you allowed shell login on the switch for the user whose account you are using for testing?
marksenteza Wed, 03/28/2007 - 02:56
My Switch is running IOS 12.1
I have Radius configured, as I have a Microsoft IAS running Radius Standard.
When I go to the Event Viewer the message I get is "A Radius message was received from an invalid RADIUS client IP Address x.x.x.x"
Source: IAS; Event ID:13
acomiskey Wed, 03/28/2007 - 05:59
  • Green, 3000 points or more
You must not have defined the correct ip address for the radius client (the switch) in IAS.
marksenteza Wed, 03/28/2007 - 06:30
I did.
But I'll tell you what fixed my problem...restarting the IAS service on the Microsoft box running the Radius Server.
Successful login was intermittent and slow, but its now stabilised.
