How to translate this
Answered Question
Mar 27th, 2007
I have a webserver that is on my inside network. I created a NAT that translates a public Ip to inside Ip and it works great.
The only problme I have is that I cannot access from inside the Public IP of the internal webserver. How do I setup this reverse translation?
Correct Answer by acomiskey about 10 years 3 months ago
There are 2 good options here
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968d1.shtml#
If you are using an external dns server, the first option will work well, dns doctoring. The second option is hairpinning, which will allow the traffic to enter and exit the inside interface with a static nat.
Overall Rating: 5 (1 ratings)
acomiskey Tue, 03/27/2007 - 08:02
  • Green, 3000 points or more
There are a few solutions for this but depends on what code you're running, is this pix or asa?
You can edit the HOST file on your machine to point to inside address. You can do dns doctoring if using an external dns server. You can do hairpinning if you are running code 7.
Correct Answer
acomiskey Tue, 03/27/2007 - 10:08
abinjola Tue, 03/27/2007 - 10:50
  • Cisco Employee,
ok use these commands :-
same-security-traffic permit intra interface
static (inside,inside)
cl xlate
cl loc
norriscr1 Tue, 03/27/2007 - 11:52
!!! Just be careful running the "cl xlate" command in a production environment. That could really impact your current traffic and cause the phones to ring.
abinjola Tue, 03/27/2007 - 12:30
  • Cisco Employee,
were the commands helpful..?
