Redistribution from RIP to BGP metrics
Mar 27th, 2007
I have a router with a WAN connection to a RIP network, and I am redistributing RIP into BGP, I have a eBGP neighbor off my redistribution router. On my RIP route when it gets to my eBGP neighbor I get a metric set of 1 on my route.
10.133.160.0/23 198.5.107.1 1 0 65000 ?
What is the best way on my redistribution router to remove that metric on my advertisements?
Any ideas?
Chris
royalblues Tue, 03/27/2007 - 10:51
  • Green, 3000 points or more
Is it affecting something?
you should be able to use a route-map and set the metric to 0 while redistributing
Post your configurations
HTH,
Narayan
